LeeJaeYoung
As the column enters, the opening line becomes thinner.
How do I get this line to be the original line?
after display order
AC27 on window 11
1 Solution
Erwin Edel
All I managed to do is draft a polyline with the proper thickness on top of it, to make it look tidy.
As far as I know you're not doing anything wrong and Archicad is being weird.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Go to post
2 Replies 2
Erwin Edel
www.leloup.nl
LeeJaeYoung
thank you so much.
I also think it's a bug.
If you don't want to draw a line, you should set it to 0.
And you will have to raise the wall up.
AC27 on window 11
