2009-09-17
03:20 PM
2023-05-26
02:31 AM
Gordana Radonic
2011-01-25 02:45 PM
2011-01-25 03:45 PM
2011-01-25 04:30 PM
vfrontiers wrote:Thanks V, It mainly happens with dwg's but occasionly with PDF. I've often wondered whether it is caused due to me putting in a number of spaces between the drawing name and revision letter. I do this to get the revision letter to appear in the right place on the title block at the same time of exporting the file types as a different name within publisher to enable me to keep a record of old revisions.
Does it happen with ALL file types?
2011-03-02 05:33 PM
Fez1974 wrote:Our technique has been to incorporate the revision letter in the name of the file in the Publisher dialog, and therefore to change the name manually each time a revised version of the drawing is published. You have to do it for DWGs and PDFs separately of course, and in answer to Vfrontiers' question, yes the problem occurs with PDFs as well as DWGs.
Over the past 12 months have you overcome this "bug" or changed your system of revising drawings at all?
2011-03-02 05:55 PM
2011-03-02 06:12 PM
2011-03-07 10:19 AM
2011-03-07 01:23 PM
vfrontiers wrote:Duane,
Revision TEXT would be great.. but it has to be tied to EACH INDIVIDUAL LAYOUT... We could already use the PROJECT INFO for revision, but it will make a GLOBAL CHANGE..
If we could only access those CUSTOM TEXT items that are available in the PROJECT INDEX environment as an AUTOTEXT on the layout itself... then each layout could be individually changed and this number could be coordinated from INDEX to TITLE BLOCK...
Don't know if I've explained it clearly... but that's my vote...
In addition, I use these little custom texts to display UPDATE DATE on my index (sort of like an ISSUE DATE, but again, individual for each layout).. Would be nice to display that same info on the sheet itself.
another Moderator
2011-03-07 01:31 PM
2011-03-08 01:00 PM
ejrolon wrote:I've entered it under 'Publishing Wishes'
Duane,
This should be a poll.
