Composite walls intersection wrong?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2022-09-02 07:09 AM - edited 2022-09-02 07:13 AM
Hi guys, I have a problem. When the composite walls intersect, the mortar layer is not closed. I think I set the material right. but why the mortar is not cover the concrete wall end.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-09-02 07:27 AM
The concrete (760) is stronger than the mortar (300) so it will cut the mortar away.
In this particular case you will need to duplicate the mortar and have an internal mortar (300) and an external mortar (761+).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-09-02 08:22 AM
Thank you Barry, But I think this will cause some addtional problems.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-09-02 08:49 AM
Yes it will.
Try this - not sure if it will work.
Leave the mortar at 300.
Set the concrete and the brick to the same strength (say 600).
I know if you have a brick wall joining a brick wall or concrete joining concrete, it will work as they are the same strengths, but also the same building material.
I am not sure if different building materials with the same strength will do the same.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-09-02 08:52 AM
1. Change the mortar back to 300
2. Use the Wall End Tool. It's under "more" in your toolbox or
3. Use a complex profile and column
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-09-02 09:03 AM
Yes this should work.
Different building materials - same strength stronger than the mortar skin.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-09-02 09:08 AM - edited 2022-09-02 09:09 AM
Use the junction order to control which way the corner joins.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-09-02 09:16 AM
Thank again Barry. I will try this way.🤝
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-09-02 09:32 AM
In my humble opinion Wall End tool is much easier to use once than to create the same strength of building materials. Because then there may be problems with the intersection and set the junction order every time.
But that is only my opinion.
AC 8.1 - 27 INT/POL 3001
Win11 | Ryzen 5600 | 16 GB | GTX 1650
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-09-02 10:01 AM
How do you place a wall end on a corner wall?
Do you have to break the corner connection (i.e. reduce length of wall), then place the wall end, adjust wall end to sizes you want and then re-trim the corner?
I can get it to work that way, but that seems a lot of work to do at each corner.
With the correct building materials set up in your job (and ideally template), it is all automatic as you place the walls.
