HJ1
Convert cover fills presentation drawing to line drawing
HI
i made a presentation drawing from the line drawing using cover fills setting of slab and other elements ...now i want to to convert that drawing back to the line drawing,but without losing the settings of cover fills which i had done in it...like i want to switch between the 2 drawing presentation with cover fill and line drawing i.e without cover fills....is it possible??
 this is the presentation drawing made using all cover fills
Thank you
Setup info provided by author
3 Replies 3
You could set up a Graphic Override to change the cover fills to empty or solid white.
The save 2 views, one using the GO and the other not.
HJ1
can you pls elaborate your last line.i didnt understand that.
aarkell
I second Barry's response. You could duplicate your view of the presentation drawing and apply a different graphic override (GO) combination. That combination would have a rule that changes all cover fills to be either white or empty, giving the appearance of just a line drawing without the fill colors.
So you would end up with two views. The one you show in your image and a new one, each with its own GO combination.
Andrew Arkell
AC 18-27 USA 5030
HP Z6 G4 Workstation | Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz | Windows 11
