Henrique
Custom Label not working on sheet
I created a custom label to get the base level of the slab. And it works fine.
But not on the sheets:
11 Replies 11
Qualifa
Hello!
Note whether you have plans automatically updated with subsequent edits, if not, try manually.
Alternatively, save the current plan view and place it on the sheet this way.
Proud member of UNION.ARCHI Network
Henrique
Thanks for the answer, Qualifa.
The drawing is updated and saved as a view.
But to left no doubts, i updated it again and recreated another one..
I also updated the software.
The issue remains... and i think it's a bug. But i can't find where to report the bug..
Qualifa
@Henrique, what is the status of the problem today?
I have found a guide for you which may help: Updating Zones
But it deals with the zone field itself, but not with the annotation, perhaps you will find something for yourself
Vinicius Guedes
Hello, @Henrique
Could you send me a .pla copy of the file via WeTransfer, please?
I couldn't reproduce your issue.
Henrique
Hello, i am still having this problem.
Thanks, but that wont fix my custom labels, unfortunately
Henrique
Olá @Vinicius Guedes , obrigado pelo contato.
Eu vi seu e-mail no suporte, mas só depois do meu horário de expediente.
Estou fazendo o upload para o WeTransfer (1 Gb, sinto muito hehe).
Vou lhe enviar o link por e-mail assim que estiver pronto!
The official language of the forum is English so please always use English even if you could understand each other in another language.
Translation by Google:
Hi @Vinicius Guedes, thank you for contacting.
I saw your email at support, but only after my office hours.
I'm uploading to WeTransfer (1 Gb, sorry hehe).
I'll email you the link as soon as I'm done!
Robby
I have the same problem. I have a custom label that displays correctly in view map but loses its values in Layout. See screen shots:
Rob Marelli
AC 28.1
MacBook Pro (2023) M3 Max -48 Gb RAM - Sequoia 15.3.2
@Henrique @Robby This is a known bug in AC 25 that reportedly will not be fixed until Update 2, coming later this fall.  See this thread:
https://community.graphisoft.com/t5/Document-Visualize-forum/Autotext-problem-between-view-amp-Layou...
