2014-12-04
11:03 PM
2023-05-30
12:26 PM
Rubia Torres
2014-12-12 12:02 AM
Barry wrote:+1
My wish is that details and worksheets were live with the model with the option to change them to 'Drawing' just like we can now with sections and elevations (that's why I use sections for details).
2014-12-12 07:33 PM
Barry wrote:The way that this works in Revit is that the model is always live (sections, details [plan or section]). Any "annotation" that you put in those views (including detail items like a 2x member for example), stays there as the model updates live. What is great about that is that you can use the sections/details to check the design and back and forth. Make a change in the model, check the detail and modify as needed or detail in a different way as a response to the model.
2014-12-12 08:30 PM
2014-12-13 10:27 AM
2014-12-14 08:50 PM
DGSketcher wrote:+1
I don't see the benefit of live details. The level of detail in the model is usually far from being accurate enough for say a 1:5 detail with fixings, membranes and complex manufacturers profiles. In my workflow I use the detail tool to create the basic line work, adapt it to suit and if necessary use the trace option to check any changes in the live source.
I agree it would be useful to keep a detail live while the drawing set is being developed but I would definitely want to be able to break the link once additional 2D information is added.
2019-11-01 02:38 AM
DGSketcher wrote:-1
2019-11-01 10:37 AM
2019-11-03 03:47 PM
2019-11-05 03:31 AM
2019-11-05 04:22 AM
