Dimension snap point on complex walls
Zendrix
Hi!
Im trying to annotate dimensions on a complex profile wall (2cm plaster/stone/2m plaster), but the snap point does not grab the exact corner of the wall but a point dislocated 2cm from the corner, on the exterior line of the wall. This only happens when i have windows on those walls. It looks like archicad draws the 2cm plaster around the hole of the window but then it does not recognize it as a grabbing point.
I already had the same trouble while modeling and i even had to design the slabs having those points in consideration (instead of the actual finished corner), which gave me some room for mistakes.
What am i missing?
Z
AC28 . LeNovo Y520 Intel Core i7-7700HQ @ 2.80GHz 8GB RAM. Windows 10 Home
AllanP
Hi Zendrix,
in the Archicad 27 Aus version you have the dimension settings for wall closure:
also,you may want to check the dimension detail settings if you are not picking up the skins you want.
I don't know if this helps.
I have been using ArchiCAD continually since ArchiCAD 4.5, 4.5.5, 5, 5.1, 6, 6.5, 7, 8, 8.1, 9, 10, 11, 12, 13, 15, 18, 21, 22, 25, now testing 28
Member of Architalk since 2003, but missed the migration to Graphisoft.
5 REPLIES 5
Jeff Thompson
Reply message removed.  Someone else had a solution.
Project Manager
Rutledge Maul Architects, PS Inc., Seattle, WA
Windows 11 Pro, HP Pavilion Gaming Desktop 790, Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz 3.19 GHz, 32.0 GB RAM, 64-bit operating system.
Archicad 28 - Graphisoft Forward
Lingwisyer
Guru
That would be more a WindowDoor issue than a Wall issue as the skin wrapping is part of the windows 2D representation.
AC22-28 AUS 3001Help Those Help You - Add a Signature
AllanP
Hi Zendrix,
Hey Allan!
Thanks a lot, the "dimensionable in 2D" box checkmark was what i was looking for! Now i can grab that corner point with the dimension tool!
Z
correct!
