Tuesday - last edited yesterday by Laszlo Nagy
Hi!
Im trying to annotate dimensions on a complex profile wall (2cm plaster/stone/2m plaster), but the snap point does not grab the exact corner of the wall but a point dislocated 2cm from the corner, on the exterior line of the wall. This only happens when i have windows on those walls. It looks like archicad draws the 2cm plaster around the hole of the window but then it does not recognize it as a grabbing point.
I already had the same trouble while modeling and i even had to design the slabs having those points in consideration (instead of the actual finished corner), which gave me some room for mistakes.
What am i missing?
Z
Solved! Go to Solution.
yesterday
Hi Zendrix,
in the Archicad 27 Aus version you have the dimension settings for wall closure:
also,you may want to check the dimension detail settings if you are not picking up the skins you want.
I don't know if this helps.
Wednesday - last edited yesterday
Reply message removed. Someone else had a solution.
yesterday
That would be more a Window / Door issue than a Wall issue as the skin wrapping is part of the windows 2D representation.
AC22-28 AUS 3001 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
yesterday
Hi Zendrix,
yesterday
Hey Allan!
Thanks a lot, the "dimensionable in 2D" box checkmark was what i was looking for! Now i can grab that corner point with the dimension tool!
Z
yesterday
correct!
