‎2025-01-28
07:27 PM
‎2025-01-30
02:09 AM
Hi!
Im trying to annotate dimensions on a complex profile wall (2cm plaster/stone/2m plaster), but the snap point does not grab the exact corner of the wall but a point dislocated 2cm from the corner, on the exterior line of the wall. This only happens when i have windows on those walls. It looks like archicad draws the 2cm plaster around the hole of the window but then it does not recognize it as a grabbing point.
I already had the same trouble while modeling and i even had to design the slabs having those points in consideration (instead of the actual finished corner), which gave me some room for mistakes.
What am i missing?
Z
Solved! Go to Solution.
‎2025-01-30 06:01 AM
Hi Zendrix,
in the Archicad 27 Aus version you have the dimension settings for wall closure:
also,you may want to check the dimension detail settings if you are not picking up the skins you want.
I don't know if this helps.
‎2025-01-29 08:35 PM - edited ‎2025-01-30 06:55 PM
Reply message removed. Someone else had a solution.
‎2025-01-30 02:20 AM
That would be more a Window / Door issue than a Wall issue as the skin wrapping is part of the windows 2D representation.
Hi Zendrix,
‎2025-01-30 12:09 PM
Hey Allan!
Thanks a lot, the "dimensionable in 2D" box checkmark was what i was looking for! Now i can grab that corner point with the dimension tool!
Z
‎2025-01-30 12:10 PM
correct!
