Zendrix
Dimension snap point on complex walls
Hi!
Im trying to annotate dimensions on a complex profile wall (2cm plaster/stone/2m plaster), but the snap point does not grab the exact corner of the wall but a point dislocated 2cm from the corner, on the exterior line of the wall. This only happens when i have windows on those walls. It looks like archicad draws the 2cm plaster around the hole of the window but then it does not recognize it as a grabbing point.
I already had the same trouble while modeling and i even had to design the slabs having those points in consideration (instead of the actual finished corner), which gave me some room for mistakes.
What am i missing?
Z
AC28 . LeNovo Y520 Intel Core i7-7700HQ @ 2.80GHz 8GB RAM. Windows 10 Home
1 Solution
AllanP
Hi Zendrix,
in the Archicad 27 Aus version you have the dimension settings for wall closure:
also,you may want to check the dimension detail settings if you are not picking up the skins you want.
I don't know if this helps.
I have been using ArchiCAD continually since ArchiCAD 4.5
Member of Architalk since 2003, but missed the migration from Architalk to Graphisoft Communities. Melbourne, Australia
Go to post
5 Replies 5
Jeff Thompson
Reply message removed.  Someone else had a solution.
Project Manager
Rutledge Maul Architects, PS Inc., Seattle, WA
Windows 11 Pro, HP Pavilion Gaming Desktop 790, Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz 3.19 GHz, 32.0 GB RAM, 64-bit operating system.
Archicad 28 - Graphisoft Forward
Lingwisyer
Guru
That would be more a WindowDoor issue than a Wall issue as the skin wrapping is part of the windows 2D representation.
AllanP
Hi Zendrix,
Zendrix
Hey Allan!
Thanks a lot, the "dimensionable in 2D" box checkmark was what i was looking for! Now i can grab that corner point with the dimension tool!
Z
Zendrix
correct!
