‎2021-03-04
07:38 AM
‎2022-09-29
01:33 PM
Oleksandra Vakariuk
‎2021-03-04 10:58 AM
‎2021-03-04 03:20 PM
Yvonne wrote:This is a bug which is fixed in the newest build. (AC 24)
... dimensions are associated with columns.
‎2021-03-24 02:18 PM
‎2021-03-26 01:24 PM
Syi wrote:Hello,
Our firm just switched over to v24 and we are all having this issue with dimensions disappearing from all sorts of drawings: plans, elevations, etc. In some instances the dimension is snapping it witness line somewhere off into space and other times the dimension itself has completely disappeared. When I add a new dimension string, the old string that had disappeared then returns.
MAJOR EFFING PROBLEM, GRAPHISOFT.
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
‎2021-09-20 05:50 PM
I am working in v25 and am experiencing this with multiple projects...EXTREMELY frustrating and problematic!
‎2021-09-20 11:51 PM - edited ‎2021-09-20 11:53 PM
@Yvonne Just in case this is something simple vs a bug: have you checked your Renovation Filter (in the Renovation Palette - or the quicklink along the bottom of the screen) when in a view that shows the dimensions vs a view that does not --- and checked the renovation status of the dimension itself ('demolish' or 'new construction')? That could be causing dimensions to appear and disappear if things were not set up properly.
Edit: Silly me. Replied to a 6 month old post. But, hopefully this might help someone searching for a similar issue....perhaps @TracyGA ?
‎2021-09-21 01:12 AM
We had checked the renovation status, model view etc but i think its a bug because we haven't had the issue since. Thanks for replying !
‎2021-09-21 06:15 PM
Agree with Yvonne. The drawing is set up correctly and since everything is new on the project I'm working in the "new" renovation only. Also, where I have a full string of the dimensions it usually doesn't delete the entire string. Instead it will delete connections to window markers, wall cores, etc. so that I end up with only an overall dimension.
‎2021-09-21 11:28 PM
There is a known bug in AC25 that means dimensions loose their connections if the relevant hotspot is missing from a different view on the same storey e.g. you have one view at a cut height and another at a different height or the layers containing connections change so the hotspots are hidden. I am assured by GS that the fix is in the next update sometime before the year end...
