Disappearing grid elements from sections in AC20
In AC 20 7001, sections
- with their gridlines set to show 'all stories, only selected', with say 50% of the perpendicular grid elements selected,
- with their views brought as drawings and showing OK,
are suddenly losing all their gridlines but one (they keep only '1' (first one on the x axis) and 'A' (first on the y axis), so that only one of them shows in each section (because the other one is not perpendicular); in some cases they keep a couple more gridlines. I go to section marker and all the grid elements but these two are now unchecked. In some cases when I go to section settings I find a lot of the perpendicular gridlines are checked instead.
I don't think I or anybody else modified anything in the section settings, and especially not in the grid elements panel. Redoing it is a lot of work, and I fear I may lose everything again.
12 Replies 12
One thing I know is that if the Grid Element is not exactly perpendicular to the Section/Elevation line then it will not appear in the Section/Elevation unless the "Show non-perpendicular Grid Elements" checkbox is checked.
If the "Grid Tool" panel is not present in the Section/Elevation Settings Dialog, then you should check the Work Environment to see if it is enabled in the "Tool Settings Dialog Boxes" page.
Aaron Bourgoin
This isn't the problem. I checked.
The elevations and sections (or their grids and grid dimensions worked fine, then someone did something and now they all need to be reset, one section elevation at a time. Since the people this happened to have no idea what happened, I need to try and figure out what changes in the model might have resulted in the loss.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.34 Mac
MacOS Tahoe 26.5.2
yei
I've been having the same problem just now. All the while I thought it was due to some settings I've changed within Grid settings - but no, it was linked to what Pens & Color settings I picked currently.
Do try this - it might work on your project too.
Go to your Floor plan - pick the problematic Grid - > Right click pick "Grid Element Selection settings" --> under "Marker" check on your Marker Pen color (see whether the assigned marker pen corresponds with something hidden or transparent color in your current Pens & Color)
If that is the case, then you can just change the "Marker Pen" color assigned and then you will see the grid element visible again in all views.
Hope this helps.
