Drawing Settings - Titles
TRN
V28: Transfering drawing titles via Favorites or eyedrop does not work. No parameters are transferred.
Operating system used: Mac Apple Silicon 14 & 15
TRN
Solved. Element transfer settings inadvertently changed to something other than "Transfer All Settings".
5 REPLIES 5
TRN
PYA
When i click view solution in original post link. it seems like link is broken.  would you please fix.
Archicad 25-27
MacBook Pro M1 Max 64GB Sonoma 14
There is nothing wrong with the link.
Which just happens to be the only other post in this thread (until you replied).
So it may look like it is not linking to anything, but is is.
PYA
Can you provide me a little more instructions about your solution. I still was not able to solved this. I dont know what is “something “. Thanks,
Archicad 25-27
Thanks,
Archicad 25-27
Setup info provided by author
