ā2022-02-25 05:39 PM
I've had this problem for the longest time and I can't seem to figure it out. Everytime I export a floor plan to jpeg format, the file looks so blurry and I can't read anything.
The way I export the files are as follow: Organizer: Select the files> choose pjeg or tiff for under Format and this is the quality that I'm getting. What are the other ways I could try so the image looks much better?
ā
ā2022-02-26 04:32 AM
What exactly you trying to do with this vector base data exported as jpeg? As its not rendered image controlling on its resolution is not in control.
ā2022-02-26 11:34 AM
Why are you exporting to JPG?
What do you want to achieve?
ā2022-02-26 11:56 AM
I would say you need to learn how to define the views and place them on the layouts... think View=Model Space, Layout=PaperSpace, but MUCH better. Lots of good videos on the Archicad YouTube channel on the topic. Start watching.
ā2022-02-28 02:19 AM
Generally I would export them as PDFs and the drawing would look perfect, but my company uses a software that doesn't accept PDF so I need to convert them all to images.
ā2022-02-28 02:46 AM
The only way I know to control the quality of a JPG file is when you render it.
But you can only render from a 3D window - so no help here.
All I can think of is to save as a PDF.
Then find a PDF to JPG converter out there in the interweb.
I have never tried any so have no recommendations of if they even work or if you can control the quality still, but there seems to be plenty out there.
ā2022-02-28 03:05 AM - edited ā2022-02-28 03:06 AM
Place the PDF as a Smart Object in Photoshop / Affinity and set the sheet DPI to what ever is still suitable for when you zoom in then save it as a JPG.
