Hide section line in plane
Hi all..
I have a section line in ground floor .. with vertical range (0-300)..so that section does not show any thing from first floor ..How can I hide section mark (section line ) which appear in the first floor and second floor .
thank you in advance
Erwin Edel
Select the section, go in to the settings, in the general tab there will be 'Show on Stories', here you can pick where the markers are visible. Default is all stories, generally.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
thank you Erwin Edel. It works .
