2010-03-26
01:25 PM
2024-12-30
04:23 PM
Molinda Prey
2018-01-24 02:37 PM
Barry wrote:Could you please specify how you select which elements (only those in use in the project) to show, and only once? Every wall shows up as an independent line in my schedule (AC 21).
In version 20 you can add section, plan and 3D previews of the 3D elements (i.e. not for 2D fills) right there in the schedule.
2018-01-25 01:27 AM
2018-01-25 02:11 AM
mattiasdh wrote:The schedule will include every wall in you model unless you start to do things like add a unique ID to the wall and then add criteria to schedule only walls with that unique ID.
Thanks in advance!
2018-01-25 07:38 AM
2018-01-25 07:42 AM
2018-01-25 02:48 PM
Barry wrote:Argh why didn't I see that before!!
'Merge Uniform Items'
2018-01-25 02:56 PM
Steve wrote:Don't they get included in your total quantities that way? Or are they 2D representations?
YI use a pre-modeled assembly of Wall Types that can be pasted into the project as a Wall Legend.
2018-01-26 03:17 PM
2018-01-26 09:43 PM
DGSketcher wrote:That sounds great.
Steve, How are you annotating your detailed wall type views?
In AC21UK (5010) I am finding using labels for schedule view annotation generally crashes the prog. Adding a description in Cats & Props doesn't allow line breaks, so you can't list the skins there line by line.
In a ideal world I would be using the Axonometric view in the schedule and either labelling with a description or with numbers linked to keynotes but I can't seem to do either.
