2025-07-03 02:58 PM
Hello!
We have different phases in the project, each one with its own revision / issue history.
The design phase with the client, then submission to authorities, then tender, construction, etc. When starting a new phase I need my revision history back to zero as we usually use the same file. The only way I know how to do this is reopening transmittal sets and delete them. That is extremely tedious when I have more than hundred transmittal sets.
Is it possible to reset to zero quicker?
2025-07-03 11:08 PM
Yes, unfortunately, the only way to do it is what you said: reopen the last Transmittal Set and delete it, then reopen the next last Transmittal Set and delete it, and so on.
2025-07-04 09:52 AM
oh my... Is there a wish for it?
2025-07-04 11:30 AM
have you tried creating a new transmittal set instead of reopening?
my other concern about the transmittal set is the dates it cannot be modified if they want to use the old dates.
2025-07-07
10:04 AM
2025-07-07
09:04 PM
Have not tested this, but can you manually set the revision to a number / letter that has already been used? If you can, depending on how you are tracking them, you might be able to filter what is displayed based on a criteria.
That is a setting in the Revision History Detailed object that I use. If you can do something similar, it might be easier? It does mean retaining a whole lot of revision information which may or may not be a good thing.
Ling.
2025-07-08 07:46 AM
Yeah, I guess I could change to letters instead of numbers and I could also duplicate the layouts and delete the issued ones. But that still keeps the revision history. Doesn't that men the file heavier? My files arre pretty big already 😞
2025-07-08 07:50 AM
"have you tried creating a new transmittal set instead of reopening?"
The problem is I need to start all revision from zero for each phase. And that I have 100 revisions and want to reduce the size of the file
The dates are not a problem as I created a new property for the transmittal sets for the date and I put it manual so I can put any date I want
2025-07-08 08:01 AM
It does not allow you to duplicate revisions.
2025-07-08 08:02 AM
Yeah, it does mean all of your legacy revision and trasmittal information is retained...
2025-07-08 08:29 AM
I guess the logic is that these transmittals and revisions are supposed to be a permanent record of what has happened to the project, and they really should not be edited or manipulated.
But I can see it would be a problem if you were to use this project as a template to start a new one.
You would want the same file setup, but a clear list of transmittals/revisions.
Maybe one for the wishlist?
