How to reset the whole layout book revision / issue history?
Leire Bilbao
Hello!
We have different phases in the project, each one with its own revision / issue history.
The design phase with the client, then submission to authorities, then tender, construction, etc. When starting a new phase I need my revision history back to zero as we usually use the same file. The only way I know how to do this is reopening transmittal sets and delete them. That is extremely tedious when I have more than hundred transmittal sets.
Is it possible to reset to zero quicker?
16 REPLIES 16
Yes, unfortunately, the only way to do it is what you said: reopen the last Transmittal Set and delete it, then reopen the next last Transmittal Set and delete it, and so on.
oh my... Is there a wish for it?
ryejuan
have you tried creating a new transmittal set instead of reopening?
my other concern about the transmittal set is the dates it cannot be modified if they want to use the old dates.
WINDOWS 11 PRO
Guru
Have not tested this, but can you manually set the revision to a number / letter that has already been used? If you can, depending on how you are tracking them, you might be able to filter what is displayed based on a criteria.
That is a setting in the Revision History Detailed object that I use. If you can do something similar, it might be easier? It does mean retaining a whole lot of revision information which may or may not be a good thing.
Ling.
Yeah, I guess I could change to letters instead of numbers and I could also duplicate the layouts and delete the issued ones. But that still keeps the revision history. Doesn't that men the file heavier? My files arre pretty big already 😞
"have you tried creating a new transmittal set instead of reopening?"
The problem is I need to start all revision from zero for each phase. And that I have 100 revisions and want to reduce the size of the file
The dates are not a problem as I created a new property for the transmittal sets for the date and I put it manual so I can put any date I want
It does not allow you to duplicate revisions.
Yeah, it does mean all of your legacy revision and trasmittal information is retained...
I guess the logic is that these transmittals and revisions are supposed to be a permanent record of what has happened to the project, and they really should not be edited or manipulated.
But I can see it would be a problem if you were to use this project as a template to start a new one.
You would want the same file setup, but a clear list of transmittals/revisions.
Maybe one for the wishlist?
