Inconsistent Right Click for Section Markers
Patrick M
Mentor
some section markers give you the "open view with current settings" and "open views from section" options, others don't. They are both source markers, they both have saved views (both are in the same clone folder of the view map). What gives?
1 REPLY 1
AllanP
The only way i get that to happen is if the section type is an "Unlinked marker"
can you access the views in the cloned view set?
I have had corrupt drawing before where things misbehaved.
have you tried an open and repair?
(p.s. had to revise answer)
I have been using ArchiCAD continually since ArchiCAD 4.5, 4.5.5, 5, 5.1, 6, 6.5, 7, 8, 8.1, 9, 10, 11, 12, 13, 15, 18, 21, 22, 25, now testing 28
Member of Architalk since 2003, but missed the migration to Graphisoft.
