Layout Book & Publisher set Settings
Gisele
blck.jpg'
The text in the master is black but it shows as red in the Layout Book & Publisher set.
Any idea on how to correct this issue?
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
It is a Work Environment setting.
Simply so you can tell what is on the master layout as opposed to the layout itself.
It will all print in its correct colours.
It worked! Thank you, Barry!
