Guru
Level Marking in Section and Elevation for a Site with Multiple Buildings
https://community.graphisoft.com/t5/Document-articles/Level-Marking-in-Section-and-Elevation-for-a-S...
Since their object was open source, I modified it to allow for more flexibility. Would be nice to be able to Call loaded storey markers, but I could not figure out how to override the text...
Ling.
26 Replies 26
Djordje
Thanks!
Love your signature... when it breaks, watch out for the pieces flying... they might be sharp!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Guru
Updated the object to allow for the marker line to be moved and added an option to swap ground from 0 to 1.
There is an issue with the basement arrays though... One is not updating and the rest are only updating when the number of storeys is changed rather than when the number of basements change...
Ling.
Guru
Fixed the basement arrays not updating.
Added origin horizontal offset.
Fixed custom name numbering.
Guru
Retain custom settings when toggling base reference
Added option to snap to project zero
Tried your object, but archicad don't want to open/charge it.
EDIT: Was a problem with my zip extractor, file ok!
Archicad 27 - GDL - PYTHON
Guru
Added option to flip individual marker heads
Added notes about adding your custom marker heads
Fixed hotspot positions when a vertical marker offset was set before turning off said marker
Guru
Fixed individual flip hotspots interaction with global flip
Added option to split names across two lines
Guru
Added option to snap to project storey stucture
Added option to use project storey names
Added option to toggle off individual storey grids
Storey names retained when toggling reference storey
Bug: Toggling reference storey results in an error which can be resolved by increasing then reverting the storey count.
Guru
Fixed some overlapping hotspots.
Fixed prefix numbering when ground is zero.
Bug: for some reason the grids default to "0: Off" even though the array generation should be asigning a default of "1: On"...
Bug: for some reason the basement marker offsets are shifting storey when toggling reference storey...
