2013-12-24 10:09 PM - last edited on 2023-05-19 03:57 PM by Gordana Radonic
2013-12-24 11:24 PM
another Moderator
2013-12-24 11:42 PM
ejrolon wrote:Excellent tip! I went from 1:100 to 1:10
If I understand correctly.
What is usually done in architectural drawing is to make the scale of the drawing bigger, since the dimensions and texts are a fixed size then they will fit.
For example detail drawings in feet and inches are drawn at 1/2"=1'-0" up to 3"=1'-0" and sometimes (have not seen any recently) 3" = 1". I have no idea as to the standard equivalents in MM are but they should be easier to figure out.
TO change the scale look at the bottom of the drawing window and it should be there.
2013-12-25 03:33 PM
maccad wrote:The scale does not change the model (there are some exceptions for library parts that can be effected by scale), but does change the "paper scale" elements relative to the model. That is why it is best to set the scale (for output) before adding the notational elements.
It's a little storage [strange] how it works - the scale doesn't actually change in plan or on a layout.
