Missing automatic dimensions in schedules for random windows/doors
Maybe someone also facing similar issue that "Automatic dimensions" in door/window schedules becomes invisible. When I turn off and turn on these dimensions they still not appears for random doors and windows, need to go through every window and add these by hand. Next time I open file some dimensions also disappears.
These dimensions showing "Unit size" in "Dimensions Settgins..." tab.
GRAPHISOFT BIM Manager Training Week attendee
ArchiCAD v9 - v28 INT / NOR (5030)
cpu i5-12600K @ 5.0Ghz, ram 32GB, gpu 1060 GTX
ssd NVMe, Windows 11
ArchiCAD Discord channel: https://discord.gg/QdWxSJ33
runxel
Hero
See this thread.
Needs a special flag in the registry.
POSIWID – The Purpose Of a System Is What It Does /// Ā«Furthermore, I consider that Carth... yearly releases must be destroyedĀ»
Thanks, will try editing windows register and see if it helps.
