2020-08-18 10:33 AM - last edited on 2024-12-18 01:22 AM by Laszlo Nagy
2020-08-18 11:08 AM
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2020-08-18 11:23 AM - last edited on 2024-02-04 08:13 PM by Laszlo Nagy
Thanks Ling, I can see it now. https://community.graphisoft.com/t5/Wishes/IDs-for-Surfaces/td-p/226226?f=26&t=69273
2020-08-20 04:33 PM
SPLITLEFT ( {Property:Wall/Outside Face Surface}; " "; 1 )
2023-04-28 02:35 AM - last edited on 2024-02-04 08:13 PM by Laszlo Nagy
I've been trying to do the same with expressions using the splitting rule for surface names, examples below...
Surface Name Example - WB | Weatherboard
Expression Example - SPLITLEFT ( "{Property:Wall/Inside Face Surface}" , "|" , 1 )
However the expression editor won't recognise this & comes up with the following message "expression contains text that cannot be identified as a string literal". Have attached a screenshot of the error & setup.
Any ideas what I'm doing wrong?
2024-01-29 09:49 PM
It works for me if I remove the " _ " quote marks before and after the defined parameter.
