Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
Only FILL wants to move a little bit.
LeeJaeYoung
FILL and LABEL are together.
1. Only FILL wants to move a little bit.
What should I do?
2.Can I delete only FILL and not delete LABEL?
Should I disconnect with "Convert to independent label" and delete FILL?
Solved: Re: how do I disconnect the label? - Graphisoft Community
AC27 on window 11
2 REPLIES 2
Gerry Leonor
  1. are you sure that label is associated to the fill? if not, there's something going on with it. is that using the normal Text Label or a special kind of label? it's supposed to move with the fill. unless it's just a simple Text & not a Label.
  2. if the label is associated to the fill, then no -- you cannot delete the fill & still have the label. you can delete the label & still retain the fill, but not vice-versa.
AC25 | Win11 | 64Gb RAM | Intel i7 13700F | RTX 4070 Ti
https://discord.gg/XGHjyvutt8
thank you ^^
AC27 on window 11
