Orbit origin not changing in 3D view
Abdullah Chaus
Usually when you select an object in 3D view, the orbit origin automatically changes to that object. However, it's not happening like that in my case. I would attach a video but apparently I do not have permission to upload videos, according to Graphisoft.
Operating system used: Windows 11 Home, AMD Ryzen 5 5600H with Radeon | 3.30 GHz | 24.0 GB RAM
@Abdullah Chaus wrote:
Oh, I see.
Is this not possible in axonometric view?
Not that I am aware of.
I usually just marquee or select what I want to see and show selection/marquee in 3D.
6 REPLIES 6
Maybe your video is too large, the allowed max. size is 75 MB:
Alternately, you can post screenshots.
It's not the video file, which is only 11 MB. I think this forum has a rule of not allowing newly signed up people to post certain types of media right away (I couldn't post images in my very first question).
Anyway, I will try to explain using screenshots. The first screenshot shows the entire model. When I orbit, it orbits around the whole model, which is fine. The second screenshot shows me selecting a single element. When I try to orbit now, the orbit origin doesn't change so it's like I am orbiting around the whole model, which is super annoying.
Hope I am making myself clear 🙂
That depends on whether you are in Axonometric or Perspective view.
Perspective will rotate around what you select.
Oh, I see.
Oh, I see.
Great. Thanks Barry
Setup info provided by author
