PDF explodes as a bitmap
Gisele
I got a bitmap when I exploded a PDF. How can I anticipate if the PDF is a vector drawing or a bitmap?
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
Gortz
If you just open it in Adobe Reader and zoom in you should see if its sharp or not.
5 REPLIES 5
Gortz
Lingwisyer
Guru
If only AC detected the nodes like ACAD does...
If it is a vectorial PDF, you can detect all of the nodes (i.e. a PDF published from Archicad).
But if it is a bitmap scan (i.e. from a photocopier), then it won't.
Odd... when I place a ACAD vector PDF using the Place External Drawing option does not give me the snaps.
Maybe ACAD is not saving it in vector format.
