2004-05-03
09:44 PM
2025-01-29
04:31 PM
Aruzhan Ilaikova
2004-05-03 10:06 PM
2004-05-03 10:15 PM
2004-05-04 08:26 PM
YA.H.VE wrote:What are the import methods? Are you assigning pen numbers ot going per color? If the line weight is on, do you see different line weights when zoomed in?
1- When import .dwg in PM the print doesn't show lineweghts.
YA.H.VE wrote:These are control codes for non-HP plotters; they can be safely ignored. There is a thread on this, with full explanation at
2- Whe import .plt in PM the following message appear: Unimplemented Instruction Occurred. "MC" "QL" "AC" "SV" "EC".
2004-05-06 04:55 PM
I got two situations:Issue here is with the import process. Djordje hit on the process, but did not go very far with it. When you import a file the pens which are used by the AutoCAD user may not match with the pens which are set up in PM. You need to open the DWG file to see which pens are being used and what the weights are. Most likely there are all set to 0.99pts. This is why I have chosen to have my consultants to send me PLTs.
2004-05-07 10:28 AM
2004-05-12 04:19 PM
2004-05-25 09:46 PM
laszlonagy wrote:Not on my setup.
Yes, PlotMaker does import DWF files.
Laszlo
2004-05-27 03:01 PM
2004-05-27 04:46 PM
