Plotmaker titleblocks
KeesW
We use a mastersheet with a titleblock, and all the automatic numbering and fill in features we can find. Plotmaker assumes that inserted drawings will overlap, and obscure, the underlying titleblock if the drawings are too big. What if we want the mastersheet titleblock to overlap an inserted drawing? Could the titleblock be made to show through the drawing?
We could generate a title block in AC and import it as a drawing. However, we would loose the benefits of automation.
Any ideas out there?
KeesW
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
1 REPLY 1
Djordje
If the drawing frame overlaps the titleblock, make sure that your drawing background is set to Transparent.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
