Property Label 23 - distortion
gdford
Periodically every property label 23 in a view gets distorted (see attached images).
This is easy to fix but it is becoming a real pain.
Does anyone know how to stop this from happening?
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
I don't know if this helps but whenever I encounter a bug, I make sure that the latest Hotfix/Update is installed for my Archicad version.
In the case of AC23, Update 4 (Build 7000) was dropped only a few weeks ago.
If you have not done so, try installing it and see if it solves the issue. These updates usually contain many bug fixes.
gdford
good point - thanks Laszlo
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
