2021-03-2905:36 PM - last edited on 2023-05-1703:42 PM by Gordana Radonic
2021-03-2905:36 PM
Periodically every property label 23 in a view gets distorted (see attached images).
This is easy to fix but it is becoming a real pain.
Does anyone know how to stop this from happening?
Gary Ford Self Employed - Modeling, Estimating, Construction Archicad 12-26 AMD Ryzen 9 5900X 12-Core Processor 3701 Mhz, 12 Core(s), 24 Logical Processor(s) (RAM) 128 GB NVIDIA RTX A2000
I don't know if this helps but whenever I encounter a bug, I make sure that the latest Hotfix/Update is installed for my Archicad version.
In the case of AC23, Update 4 (Build 7000) was dropped only a few weeks ago.
If you have not done so, try installing it and see if it solves the issue. These updates usually contain many bug fixes.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac27
