Publisher PDF defaults
JohnJay
Is it possible to change the PDF defaults when setting up publisher sets and adding layouts to sets?
I almost always need to add layouts to be published and AFAICT I need to check and set PDF options every single time.
AC27 | i7990x | RTX4070 | W10
5 REPLIES 5
You can organize your Layouts into folders, and if you set the PDF options for the folder, it will be applied to all Layouts within that folder.
runxel
Hero
Yeah, that would be great if there would the possibility to have some custom default so you can be sure.
You can create a 'Shortcut' of the layouts in the Publisher Set.
That will ensure that any new layouts are automatically included in the publisher set.
Having layouts belonging to a folder does indeed mean that when you apply the PDF settings to the folder in the publisher set, all the PDF settings in that folder get amended.
But I tested, added a new layout, it automatically added to the publisher set (because it was a shortcut), but it did not adopt the amended PDF settings.
Just used the standard default settings.
Barry wrote:
But I tested, added a new layout, it automatically added to the publisher set (because it was a shortcut), but it did not adopt the amended PDF settings. Just used the standard default settings.
I will forward this to Graphisoft. This sounds to me like unintuitive behavior and the opposite of what one would suppose should happen in such a case.
JohnJay
Thanks - this seems to be working for me
Open Organiser
Create Publisher Set
Within that set, create a new folder
Drag the first layout into the folder, then select the folder and set PDF prefs
Drag other layouts in and PDF prefs are as expected
