Publishing to a single PDF file
svpribyl
Is there a way to publish multiple layouts to a single pdf file?
Thanks!
Steve Pribyl
MAC OS Sonoma 14.5
ArchiCAD 28
4 REPLIES 4
Activate the publisher set & the tick the "Merge to one PDF file" box at the bottom
dhnguyen
I have ArchiCAD 18 and I don't see the option to "merge pdf into one file". can you please show a screen shot?
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
Eduardo Rolon
Here you go.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Also arrange your publisher set so all the PDFs are in one folder.
Select that folder and tick the "Merge to one PDF file" box.
Whatever the name of the folder is, that will be the name of your PDF file.
If you have multiple folder inside another folder as in this image, you can merge the parent folder or the sub folders.
