Relink drawing is broken after update to 27.2
Martijn-MAD
Since the update to 27.2 there's a terrible bug when you want to relink a drawing on a layout or in the drawing manager. It no longer starts on the view you selected but goes straight to the top of the list. That's very unhandy, because normally I just want move just one view up or down like when relinking to another story. Is this bug a known issue and will it be fixed soon in an hotfix? (please).
The behavior before:
The behavior now after the update:
Operating system used: Mac Intel-based 14.4.1
Martijn Verbeek
Architect / Owner MAD - modeling | architecture | data
www.mad.nl
James B
The link to dialogue not pre-highlighting the currently set view, will be fixed in the next hotfix, AC27.2.1
James Badcock
7 REPLIES 7
Chuso
Hi Martijn-MAD,
Have you found any answers for this issue?
I have just noticed it and it is quite annoying.
I use "link drawing to..." quite a lot to relink views up and down as you said and also exiting / demolition / new, Option 1 / 2, etc.
Regards,
Chuso
I also expierenced this issue when relinking drawings. AC27 INT 5002, quite annoying one. Search function helped a lot.
GRAPHISOFT BIM Manager Training Week attendee
ArchiCAD v9 - v28 INT / NOR (5030)
cpu i5-12600K @ 5.0Ghz, ram 32GB, gpu 1060 GTX
ssd NVMe, Windows 11
ArchiCAD Discord channel: https://discord.gg/QdWxSJ33
James B
James Badcock
Thanks James! Is there a timeframe when the hotfix will be released?
Martijn Verbeek
www.mad.nl
Would be logical if thread will be marked as "Solved" when Hotfix is released with link to it. In our company we making things as "Done / Completed / Finished" when they are finished and implemented, not when things are still in progress . . .
Not sure, we are still finalising it internally and then need to test it.
Our support teams may have further details on a rough time frame.
James Badcock
Setup info provided by author
