Ellen
Resize frame and move frame problem - snaps to corner
Hi!
I'm having a new (previously not encountered) problem with view resizing and reposition on my sheets. When I click move or re-frame any of the views on my sheet, archicad autosnaps to something, seemingly the corner of my sheet. I set up about 10 sheets yesterday, re-sizing and moving things around within the frames and didn't run into this problem.
It's not isolated to this file either, I have another instance of Archicad open, and it now doing it that file as well.
The screenshots attached show what happens when I click to move or resize the frame, you can see the spot it want to attach everything to.
I have restarted archicad, both instances of the program, and restarted my computer. I've done a quick internet search but I'm not sure I'm accurately describing the problem to get the right how-to-fix.
Your help is greatly appreciated! I'm fairly stuck at the moment!
Thanks,
Operating system used: Mac Apple Silicon 7004 Full
Screenshot 2025-01-09 at 1.42.28 pm.pngScreenshot 2025-01-09 at 1.42.07 pm.pngScreenshot 2025-01-09 at 1.42.16 pm.png
1 Solution
CosminF
It could maybe be a grid snap issue? You may accidentally enabled it? (Alt-S is the default shortcut)
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Go to post
2 Replies 2
CosminF
Ellen
Amazing, thank you this worked! I would have never figured this out or figured out what to search for to fix it.
