Sun Settings in 3D Documenting - EDU
Hello people, first of all sorry if this is a solved problem in the forum, but i couldn't find it.
So, I'm preparing plan drawings with 3D Document but i think there's no option for the sun's angle or fill or whatever.
I'm using the Educational version, maybe that's why but idk.
Any solutions?
10 Replies 10
That is odd - the full version has some shadow settings.
The EDU is the same software as the full version it is just the licence key that is different and the files are saved as EDU files.
Otherwise there should be no difference as far as I know.
Try turning the shadows off and then on again.
Maybe someone else with EDU can have a look.
Thank you. I've already tried turning on and off, it's still the same. It's not very bad with the default settings but it'd be good to do some changes.
Eduardo Rolon
If I remember correctly, sun shadow direction is based on how it was in the 3D Window at the moment you created the 3D Doc. To adjust the sun angle in the 3D Doc:
1. right click and select 'Open Source File" this should open the 3D Window
2. In the 3D Window right click and select "3D Projection Settings" and Edit the Sun
3. Right Click in the 3D Window and select "Redefine 3D Document" and choose the correct one.
FYI the EDU and Commercial versions have the same features.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Thanks but that only worked for perspective views, not for plans. I'm in a hurry with my work right now so default options are OK for me.
But it'd be good to know how to change sun and shadow settings, especially the opacity of shadows for 3d plan documents.
Eduardo Rolon
Type of shadow is controlled by 3D Doc settings as shown by Barry.
To change sun position for 3D floor plans you need to edit the Location setting for the project and then update the 3D Floor Plan Doc by selecting "redefine"
AC29 US/INT -> AC08
Eduardo Rolon
after changing and redefining
AC29 US/INT -> AC08
Yes but notice in my screenshot I can change the shadow fill type and pen colours.
For some reason in Patrick's EDU version he can't.
In perspective/axonometric then you can also change the sun position in the '3D projection settings' but you must redefine your 3D document.
Not sure if this will affect the 3D doc from plan - don't have Archicad to test at the moment.
Yes it does.
Eduardo Rolon
About the missing shadow settings I just saw the problem and it does not look like a bug.
When you create a New 3D Doc from a Perspective you can turn shadows on but the setting items are not available until you change either "Cut or Uncut Elements" item to any other option that is not "Own Surface Colors/Shaded"
AC29 US/INT -> AC08
