derekjackson
Support for transparency in external PDFs
Hi, is there a way to enable transparency when placing PDF from external sources on a Layout?
It seems it's supported when placing a internal view, but PDF with transparent backgrounds always appear with solid white behind them?
http://www.lsiarchitects.co.uk
http://derekjackson.artstation.com
AC19 / 21 / 23 / 27
Windows 7 Intel Xeon 18Gb
Setup info provided by author
2 Replies 2
CosminF
There isn't a setting to have the PDF transparent, however, as a work-around, you can right click and Explode into current view.
This splits the PDF into its component parts and (if the PDF isn't a jpg image re-saved as a PDF) you can even edit lines, fills and text. And you can delete the white fill that is usually the PDF backdrop.
It is quite cumbersome to edit an exploded PDF but it can be done.
Hope this helps.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
parvink
Archicad (by Graphisoft) does not support transparency in external PDFs placed on Layouts—the transparent areas are rendered as solid white. As a workaround, you might try converting PDFs to PNGs with transparency retained and then place those images instead.
