yesterday - last edited yesterday by Barry Kelly
hello, i've set my interior elevation at 'surface-texture fill, shaded'.
and when I publish the documents. there are boundary lines of texture.
How can I set the texture with no boundary?
yesterday
Is this with the inbuilt publisher? Viewing in Acrobat? Are the seams visible at all zoom levels or do they flicker in and out? Are they visible if you open it in a web browser?
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
9 hours ago
1. Publisher set properties > Publishing method : Save files(PDF)
2. Seams are visible at PDF Viewer and same when printed on paper.
3 hours ago
Known issue. The visibility of the tiling of textures is a thing, depending on the viewer application and the current zoom level. For some it's more prominent than in others.
The reason boils down to float arithmetics and anti-aliasing.
It will not be visible in print.
