Vanishing Master layout information
The title blocks on my master layouts are not showing up in the layouts.
I've had some other glitches over the last week, so I reinstalled and updated last night.
This is only happening in one project (so far...).
All the master info is on the Archicad layer.
I checked pen #s to make sure they are visible regardless.
I tried making a new master layout from scratch. Still no information.
Does anyone have a clue what this could be?
12 REPLIES 12
__archiben
if you have deleted a penset that is in use by placed drawings on a master layout, that placed drawing won't show up on the layout.
go back into your master and assign it a valid penset.
multiple "archicad" layers sounds far more like DWG transfer layer mapping than cadimage - their one and only layer is called " Archicad - master only"
~/archiben
b e n f r o s t
Thomas Holm
~/archiben wrote:
if you have deleted a penset that is in use by placed drawings on a master layout, that placed drawing won't show up on the layout....
If that's true, I'd call it a bug, or maybe a serious design flaw. There should be some fall-back default , like "all pens black 0.25" or something for such a case.
__archiben
Thomas wrote:
If that's true, I'd call it a bug, ...
it is a bug. i think they got it nailed once during beta as well. we had it last week in an early AC11 build. didn't try and replicate with 1114 though.
b e n f r o s t
