2021-07-27
02:46 PM
2025-02-06
11:18 AM
Aruzhan Ilaikova
2021-07-28 03:27 AM
Sculptdesign wrote:Duplicate your
So I set an override to make all cover fills transparent, but this also applies to slabs
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | i9 11900K | 32GB | GTX2080TI |
2021-07-28 03:56 AM
So I set an override to make all cover fills transparent, but this also applies to slabsOverrideand just add an extra criteria for Is not Slab?
2021-07-28 03:49 PM
2021-07-28 04:13 PM
2021-07-29 03:50 AM
2021-07-29 08:25 AM
Lingwisyer wrote:Thanks I will try that. Stairs are an issue when they overlap, I use the fill of the current stair to hide part of the one below. We work a lot on existing buildings so the treads rarely sit directly on top of one another. When the fills are transparent it shows all the treads and doesn't make any sense! I will try the range as you suggest and see if that helps. Thanks!
Could you reduce yourRelative Floor Plan Rangeso that they are not drawn? This can be Viewspecific.
2021-07-29 09:42 AM
2021-07-29 02:21 PM
