Sculptdesign
Zone colours and object/slab fills
Hi all,
I like using zones to illustrate different areas and it works really well. However, when preparing layouts with furniture all of the object fills sit on top of the zone (as image attached).
So I set an override to make all cover fills transparent, but this also applies to slabs which I need to have fills to cover elements below, such as lower parts of stairs. If I rearrange the zone to be above the slab the zone fill covers it.
What I'm looking for is for the zone to somehow be on top of all other objects, allowing the lines through but not the fills. Like the multiply blend mode in Photoshop.
How does everyone else deal with this? I've resorted to keeping the zone fills transparent so they can still be scheduled but the colour coding was very helpful to indicate different types of rooms etc.
Thanks!
ArchiCAD 26 Solo - Mac
8 Replies 8
Guru
Duplicate your Override and just add an extra criteria for Is not Slab?
Win11 | i9 10850K | 64GB | RX6600 Win11 | i9 11900K | 32GB | GTX2080TI
Or set a criteria for 'Element type is zone'.
Then it won't affect any other elements.
Sculptdesign
Thanks for these, the issue is that the slab will then still cover the zone fill - as per the top right of the screen shot.
I can't bring the zone to the top because it will cover the stair, the stair can't be transparent because it's hiding elements below. The slab can't have a fill if the zone is below. It just seems like a catch 22.
I'm interested how others use zone colours, do people ignore that the objects are white over the zone, do they not use the colour? Am I over thinking this?
Erwin Edel
We ignore the 'white bits'. Stairs, furniture etc
But we also only use the coloured views for schematic 1:200 layouts for fire ratings, etc so these typically do not show a lot of furniture to stay legible.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Guru
The stair is covering elements below? Could you reduce your Relative Floor Plan Range so that they are not drawn? This can be View specific.
Ling.
Sculptdesign
Thanks I will try that. Stairs are an issue when they overlap, I use the fill of the current stair to hide part of the one below. We work a lot on existing buildings so the treads rarely sit directly on top of one another. When the fills are transparent it shows all the treads and doesn't make any sense! I will try the range as you suggest and see if that helps. Thanks!
Guru
Regarding stairs overlapping, use a manual cut height for the break line with the invisible above / below setting?
Ling.
Sculptdesign
Thanks Ling, I think I've tried most of the options with the stair views but the zone fill never shows how I want it to. I think it's best to change how I do my drawings to be honest and only use the zone fills for smaller scale schematic drawings. If I come across another example again I'll come back though.
