2023-06-22 03:20 AM
Text labels have started to be cut off when modeling. Same goes for text blocks. And for text displayed within objects (see the 'dryer' at the bottom of the screenshot).
I have the font installed on my machine and not sure why this started to happen all of a sudden, as these same labels/text displayed just fine a month or so ago...
I couldn't find a thread/video/etc to help me thru this, so if you know of one, I would love to learn!
Thank you.
pbg
Solved! Go to Solution.
2023-06-27 08:47 AM
If you have to use 100% scaling instead of a larger scaling factor, I would reduce the screen resolution on your monitor.
I have 4K monitors, but use them at 2560x1440 resolution, and use a 100% scaling factor.
2023-06-22 03:24 AM
I forgot to say that changing the (display) scaling factor to 100% in windows does resolve the issue, but it makes everything else unreadable (except with a microscope). Is there some other way to have the text within archicad display correctly without affecting the display properties of everything else associated with windows?
Thanks!
2023-06-27 08:47 AM
2023-07-01 08:04 PM
Thanks Laszlo!
Obviously it would be great to fully utilize the graphics card/monitors/etc, but it seems like this isn't possible... Guess I will settle for readable text.
Thanks again for your help, much appreciated.
