4 weeks ago
- last edited
4 weeks ago
I open a project from yesterday. Open Keynotes. Click on the desired folder, select the last keynote used, then click "New Keynote" button. And the name of the new keynote does not follow my naming sequence. Instead of C23 it puts in a default.
Solved! Go to Solution.
4 weeks ago
It follows on from whatever the last keynote was during your CURRENT session, else it will default to stepping KN-xx. Probably worth a wish for it to step based on the folder or keynote that you have selected.
Ling.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
4 weeks ago
Ling.
4 weeks ago
if you click the duplicate button, it will follow the naming/numbering sequence.
4 weeks ago
right, thanks. I tried just manually typing the first one, then it follows along. Thanks again.
