LOA
2d symbol with width x depth parameters as text
Hello! I'm creating a 2d symbol for a parking stall and I would like for the text on the symbol to show the width x depth of the stall based on the dimensions entered for the object. Is this possible? Please see attached.
You just have to convert the number to text.
Search the gdl reference guide for STR.
Domagoj Lukinic
You can do that but I would code it directly in to textbox like this:
paragraph		"AC_PRG_2" 1,0,0,0,1
    STR{2} ("%cm",a)+"x"+STR{2} ("%cm",b)
endparagraph
no need to add extra variable.
However if you really want it in a variable you still need to use STR{2} and also VALUES/VALUES{2} and then link that variable in text:
values "STALL_SIZE",STR{2} ("%cm",a)+"x"+STR{2} ("%cm",b)
