2023-04-13 07:27 PM
1. create DoorStyleName
2.
Displaying Properties with Labels | GRAPHISOFT GDL Center
I am trying to read this value from Marker.
Is it possible?
However, even if you look at the contents, the solution is not explained, so I would appreciate it if you could tell me where to start studying.
2023-04-13 08:15 PM
Do you mean the actual property which is set in the building component or do you mean the 4 Values from the options setup?
GS says: Only the actual property value can be accessed from GDL, the other choices aren’t visible.
2023-04-14 01:54 AM - edited 2023-04-14 01:59 AM
I want to bring only the values I selected.
2023-04-14 06:53 AM
ui_custom_popup_infield "myProperty",
70, 30, 370, 20, ! X Position, Y Position, Width, Height
1, ! Store Hidden ID
3, ! Tree Depth
1, ! Grouping Method
_displayName, ! Created value description
_parentProperties
Here in myProperty parameter function
_parentProperties with ui_custom_popup_infield
You can manually select what you want from among the
It looks like you put it in the myProperty parameter function.
Among the values in dim _parentProperties, I want to search for "DoorStyleName" and automatically insert that value into the myProperty parameter.
2023-04-19 08:07 AM
2023-04-19 08:56 AM
I think it will be easier to understand if you see the code. Please excuse me if I am not rude.
2023-04-20 12:05 PM - edited 2023-04-20 12:12 PM
If you whant seach property by name - you can try this macro. Macro find all gdl parameter or property name in string and replace it with value. You can also see a sample code for reading a search by properties (by the label "getPropertyValue").
Exemple of door marker here
Structural engineer, developer of free addon for sync GDL param and properties
2023-04-30
08:10 PM
2023-05-03
08:34 AM
Maker.gsm was successful.
I am testing on door.gsm's mater stript.
What's wrong?
n = REQUEST ("Property_Value_Of_Parent", nID, _type, _dim1, _dim2, _propertyValues)
!!! n is 0
or
propInputIds.propertyIds[1].id = nID
n = REQUEST ("Property_Values_Of_Parent", propInputIds, propOutputVals)
!!! n is 0
text2 0,0,propOutputVals.propertyValues[1].value[1]
Is it possible to access Properties inside GDL? - Graphisoft Community
Solved: Getting all property values of type 'Door' from A... - Graphisoft Community
2023-05-01 08:33 AM
("Properties_Of_Parent") also works with door / window GDL.
By the way, REQUEST("Property_Value_Of_Parent") only works for markers.
Is there a function that can obtain property values in door / window GDL? Or is it not possible to get property values from door/ window GDL?
2023-05-03 10:21 AM
It is not possible to get an element's own properties, except IFC properties with
