cocoloco
GDL language - should I use it at all?
Hi! Is there someone here who understands GDL language? I usually model my own products, but I was curious to try modeling via GDL with my friend ChatGPT,  and it didn’t go well.
As you can see, GDL is not my strength and I honestly don’t really know how it works, and wanted to test it if it would save some time - so please bear with me.
I’m just curious if it can model anything at all. I tried creating an oval table with a full bullnose top and cylindrical legs. But every time I added the script as a new object, it gave me an error — line by line — always saying “MISSING CALL.” Fix one line, and then another line would trigger the same error. Nightmare. How is this legal to work this bad? why not to say all the errors at once?
Anyway, in the end, it was recommended that, for an oval table with a bullnose top and cylinder legs, it’s actually better to leave the GDL scripting (LOL) and instead:
  • Use the Archicad Object Tool wizard to create a parametric block + cylinder table interactively rather than hand-coding.
  • Set all parameters (width, depth, height, tabletop thickness, leg diameter, leg offset) directly in the UI.
  • This avoids all MISSING CALL or sweep2 issues and ensures the object is fully adjustable in the Settings dialog.
Is there someone here who knows GDL and can confirm whether it really has these limits? Am I better off modeling objects the way I usually do? What is the gdl language used for then?
MacBook Pro, Sonoma: 2.6 GHz 6-Core Intel Core i7, Intel 16GB mem,
Archicad Solo 26 and 27 (in testing mode)
3 Solutions
Laurentiu
Yes, there are quite a few people who understand GDL.
Specific GDL questions are posted in the Developer Hub > GDL section of the community, take a look there.
I don't think chatGPT knows that much about GDL, mostly because I don't think it has that many available resources to train it off. Last time I tried it just spilled so much gibberish I gave up in like 5 minutes.
I'm not amazing at it myself or anything, but I have learned a lot in the last year and I can honestly say it's a powerful skill to have as an Archicad user and it allows you to at least have clean objects even if they are custom.
If you're curious about how it works and want to learn more, here are some resources to get you started.
BarkingDogBIM < go from the very first video and start there.
MF BIM < a short table tutorial in 8 parts, you can do this in parallel with the first link.
Make Parametric Objects in Archicad with GDL course < this is a paid course on udemy that is 100% worth it. You get to go from 0 to very complex objects and are guided all the way through gradually.
Other resources:
GDL Center
Object making with Archicad
GDL Cookbook 4
Laurentiu Cauni | Architect | AC 17-28 INT
Windows for AC & iOS for BIMx
Go to post
Every object, door and window you use from the library is scripted in GDL.
So it can certainly do a lot of things.
However, if you want to script properly, you need to learn how to do it.
There have been many posts here over the years about "how do I learn GDL".
You can of course just model elements and save them as an object, door or window.
This will automatically create a script, but the object will not be parametric (stretchy or changeable).
And it will not be a script that is easily editable to make it parametric.
It is a long learning process, so be warned.
Go to post
Lingwisyer
Guru
Regarding the attempt to code a table, there was an old GS GDL Tutorial that was about making a table. Will see if I can locate it later...
Ling.
Go to post
9 Replies 9
Laurentiu
Other resources:
GDL Center
GDL Cookbook 4
Lingwisyer
Guru
Ling.
scottjm
Mentor
If you want custom static objects and don’t know GDL it’s easiest to model with native tools and objects, moorish etc to make what you need.
if you want to create fully parametric objects GDL is extremely powerful. I would call it a super power of Archicad, but GDL is not accessible if you don’t know how to code.
Unfortunately it will take time to learn how to write GDL, if you have previous experience it will come naturally, but if you don’t it’s a long road.  @Bruce ’s youtube guides are an excellent series to start to learn  GDL.
https://youtube.com/@barkingdogbim
Ahmed_K
Mentor
I share the same doubts with you, should i learn gdl ? Is it really a good thing that will accelerate my workflow ? The answer is not a simple yes or no,
First of all, Why gdl ?
The main response is : 1 source objects, different shapes using parameters,
The strength in this is that i can have a schedule of a tables with extracted parameters from different parts, without the need of modelling various dumb tables .
Or extract that parameters with labels, at the end instead of modelling multiple dumb objects, you start from 1 object, and create smart customised instances .
In my daily workflow, 99% of my schedules don't extract gdl parameters except of doors and windows, i use the default doors and windows and it's d
Good for most of the cases.
So i abandoned learning gdl, the default library objects can do the job, if i need a custom object, i can import it as a dumb object, and i'm sure i won't even need to schedule it, and if it happens, i use custom properties.
Archicad 27
Windows 11 professional
cocoloco
Thank you for your feedback and apologize for the late response I just seen this.
I appreciate all the resources and I hope someone finds them useful who wants to learn the gdl language, but myself I don't have time for it and was curious if chatgpt could help to streamline this and if it could be faster than modeling certain items. Since it seems it is not very helpful, I guess I stick with standard modeling. But thank you!!
Laurentiu
It's part of the ArchiCAD Building Object Creation ITG - part 6 & 7...from 15 years ago 🙃
Lingwisyer
Guru
If you just learn the basics on element transformation using ADD and MUL, you can make a fair amount of basic parametric objects save out of the the floor plan.
If you model each part of a simple object on the origin, you can FIX the MUL and ZERO the ADD at the start of the automatically generated script to re-zero it. Once zero'd, you can copy paste across other parts that you can MUL to stretch, ADD to move and ROT to rotate into the desired relative positions with the inputs to these commands being parameters that you can add if you want them to be modifiable.
I have attached a light which was made this way from multiple shells that I drew on the floorplan. Given the number or parts, I GROUPed them for clarity and ease of modification but this is not needed.
Ling.
jl_lt
Ace
at this moment of the match, i would just wait till the AI learns it
