2023-09-07 01:36 PM - last edited on 2024-09-26 01:50 PM by Doreena Deng
I have a pyramid object using the pyramid command, but I would like to show the angle of each face in the floor plan. Is there a way to obtain and display that kind of information?
Juan
Solved! Go to Solution.
2023-09-07 03:01 PM
The reference manual says:
Pyramid based on a polyline in the x-y plane. The peak of the pyramid is located at (0, 0, h).
So you know your coordinates. And you know "h", since you defined it....
Now all you need is the distance of the line to p{0,0} and a bit of simplest trigonometry. Should be straightforward.
2023-09-08 03:38 AM - edited 2023-09-08 03:46 AM
θ = atn( h / a )
θa = atn( abs( ze - za ) / ( xe - xa ) )
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2023-09-07 02:28 PM - edited 2023-09-07 02:53 PM
Please illustrate your ideas and requirements with a diagram 😀
2023-09-07 03:01 PM
θ = atn( h / a )
2023-09-13 08:31 AM
Thank you all, I agree it should be pretty straight forward. I think my main issue is (as far as I know) there is no console to print values, just like in python to corroborate the values.
2023-09-13 09:10 AM
Just use the PRINT command.
If in the 2D script , view the 2D preview and you will get a message.
Same in the 3D script, view the 3D preview.
You may need to set your Work Environment to interrupt with error messages if that is turned off.
2023-09-13 09:38 AM - edited 2023-09-13 09:39 AM
If you are just wanting it to display on the floorplan, just use a text2 with the result of the above trig?
2023-09-13 11:31 AM
That did the trick, sometimes I tkae the most complicated route 😅
