2025-04-08
10:37 AM
2025-04-11
08:16 PM
Hello
I have my arched windows and doors that take an opening in the rectangle wall. I must have pressed somewhere, before that I didn't have the problem.
Solved! Go to Solution.
2025-04-10 03:34 AM - edited 2025-04-10 03:34 AM
What do you mean by "I only created the frame"?
An Archicad window already has the frame, no need to create anything.
What Archicad window are you placing?
I get the impression you are placing an empty opening and the adding the frame?
To create a custom window have a look at this ...
https://community.graphisoft.com/t5/Modeling/How-to-create-Custom-Window/ta-p/303432
This does not include the wallhole which is explained in the links at step 4.
2025-04-10 09:05 AM
Maybe it can help this video on YT
Here is how to change ID to : wallhole
2025-04-10 07:28 PM
I created the window frame, but that's not the cause of the problem, it happens with all my windows, for example the arched history window 27 of archicad without customization.
2025-04-11 03:31 AM
Does this happen in a fresh file?
2025-04-11 03:36 AM
This is strange.
I have never seen a 'shaped' window cut a rectangular hole in a wall.
Here is the same window (just version 28).
I can't think of a setting that would control this.
Does the same thing happen if you start a new file based on the default Archicad template?
2025-04-13 12:09 AM
No, there is no problem in a fresh file but when I merge my folder with a new file, the problem is still present.
2025-04-13 12:11 AM
No, I don't have this problem in a fresh file. I don't see what it can be because it happened suddenly.
2025-04-13 06:36 AM
I don't know what is happening to you in that file.
I am not aware of any settings that will ignore the shape of the wallhole and leave it only as a rectangle.
2025-04-14 06:38 AM
Have you tried a Repair on the file? Maybe something in the file is corrupting the wallhole...
2025-04-14 12:53 PM
Yes I tried, it didn't change anything... I also tried to copy and paste when I integrate a wall from another file, the window changes opening and when I paste a wall from my file, the existing windows are rectangle and the new ones are round... I think I'm going to have to put everything on another file and start my layouts again.
Copy paste from wall of new file into my file with problems
Before in a new file
Copy paste from file wall with problem into my new file with added window
