2023-03-12
01:04 PM
2025-10-01
11:32 PM
Hi, guys. Could you please help me achieve the same scale effect as in SketchUp? The Unproportional Scale is also what I need. Thank you.
2023-03-13 02:20 AM
I think you can just use the COOR commands?
2023-03-13 09:37 AM
I am already using COOR3.
bms_buildingMatAttribute_1 = 0
r = REQUEST{2} ("Building_Material_info", buildingMatAttribute_1, "gs_bmat_surface", bms_buildingMatAttribute_1)
mulx A/ 3
muly B/ 3
mulz ZZYZX/ 1
body -1
model solid
resol 36
pen penAttribute_2
set building_material buildingMatAttribute_1, DEFAULT, DEFAULT
sect_attrs{2} penAttribute_3, lineTypeAttribute_1
vert{2} 0, 0, 0, 1 ! #1 VertId=0
vert{2} 0, 3, 0, 1 ! #2 VertId=0
vert{2} 3, 0, 0, 1 ! #3 VertId=0
vert{2} 3, 3, 0, 1 ! #4 VertId=0
pen penAttribute_2
edge 1, 3, 1, 0, 262144 ! #1 EdgeId=0
edge 4, 2, 1, 0, 262144 ! #2 EdgeId=0
edge 2, 1, 1, 0, 262144 ! #3 EdgeId=0
edge 3, 4, 1, 0, 262144 ! #4 EdgeId=0
vect 0, 0, 1 ! #1
material materialAttribute_1
pgon{3} 4, 1, 2, 6, 0, -3.000758471779, -2.992290207747, 0, 1, 0, 0, 0, 1, 0, 0, 0, 1, ! #1 PolyId=0
1, 4, 2, 3
material bms_buildingMatAttribute_1
coor{3} 6, 8,
0, 0, 0,
1, 0, 0,
0, 1, 0,
0, 0, 1
body 262182
material 0
body -1
2023-03-13 09:44 AM
COOR{3} can determine the origin of the surface, it direction and the method it is wrapped, but I am not 100% sure if it can stretch the surface.
Does it need to be done in GDL or can you just create a duplicate surface and increase the size of the texture?
2023-03-13 09:52 AM
it should be a GDL, I need it for the multiple-use case.
2023-03-13 05:17 PM - edited 2023-03-13 05:19 PM
It's possible to scale a texture dynamically by having a DEFINE TEXTURE with scaling variables (and then doing a DEFINE MATERIAL with said texture) but I don't know if it's possible to extract the texture name from a REQUESTed material.
If you already know which texture you want, you could hardcode it directly maybe.
2023-03-13 05:53 PM
It's possible, even tho you must need to do some contortions.
file_name = ""
rrr = request{2}("Material_info", old, "gs_mat_texture", file_name, w, h, mask, alpha)
define texture "new" file_name, w*2, h*2, mask, alpha
tex_id = ind(TEXTURE, "new")
str_name_of_mat = ""
rrr = request("Name_of_Material", old, str_name_of_mat)
define material "new_mat" based_on str_name_of_mat,
parameters gs_mat_texture_ind = tex_id
mat_id = ind(MATERIAL, "new_mat")
material old
brick 1,1,0.1
addx 1.3
material mat_id
brick 1,1,0.1
Don't get hurt.
2025-10-01 02:56 PM
I copied and pasted your script (created the "old" parameter) and got the error message, am I doing something wrong?
"Error in definition of materials used at line 21 in the 3D script of file Untitled-1.gsm."
2025-10-01 05:24 PM
Could be a GDL bug? I encounter this too, in AC 28.
However it still works. So I'm not really sure why it's nagging here.
2025-10-01 07:45 PM
Yes, it's working, but this error message is very annoying. Thanks for the reply.
