galiaf_velikiy
Scale or Stretch Texture on the Surface
Hi, guys. Could you please help me achieve the same scale effect as in SketchUp? The Unproportional Scale is also what I need. Thank you.
11 Replies 11
Lingwisyer
Guru
I think you can just use the COOR commands?
galiaf_velikiy
 I am already using COOR3.
bms_buildingMatAttribute_1 = 0
r = REQUEST{2} ("Building_Material_info", buildingMatAttribute_1, "gs_bmat_surface", bms_buildingMatAttribute_1)
mulx	A/           3
muly	B/           3
mulz	ZZYZX/           1
body    -1
model solid
resol       36
    pen     penAttribute_2
    set building_material buildingMatAttribute_1, DEFAULT, DEFAULT
    sect_attrs{2} penAttribute_3, lineTypeAttribute_1
vert{2}	           0,            0,            0, 1	!	#1   VertId=0
vert{2}	           0,            3,            0, 1	!	#2   VertId=0
vert{2}	           3,            0,            0, 1	!	#3   VertId=0
vert{2}	           3,            3,            0, 1	!	#4   VertId=0
pen penAttribute_2
edge	   1,    3,    1,    0, 262144			!	#1   EdgeId=0
edge	   4,    2,    1,    0, 262144			!	#2   EdgeId=0
edge	   2,    1,    1,    0, 262144			!	#3   EdgeId=0
edge	   3,    4,    1,    0, 262144			!	#4   EdgeId=0
vect	           0,            0,            1	!	#1
material materialAttribute_1
pgon{3}       4,    1,    2,    6,    0, -3.000758471779, -2.992290207747,            0,            1,            0,            0,            0,            1,            0,            0,            0,            1,	!	#1   PolyId=0
		   1,		   4,		   2,		   3
material bms_buildingMatAttribute_1
coor{3}	   6,    8,
	           0,            0,            0,
	           1,            0,            0,
	           0,            1,            0,
	           0,            0,            1
body	262182
    material 0
    body    -1
COOR{3} can determine the origin of the surface, it direction and the method it is wrapped, but I am not 100% sure if it can stretch the surface.
Does it need to be done in GDL or can you just create a duplicate surface and increase the size of the texture?
galiaf_velikiy
it should be a GDL, I need it for the multiple-use case.
MetalFingerz
@galiaf_velikiy ,
It's possible to scale a texture dynamically by having a DEFINE TEXTURE with scaling variables (and then doing a DEFINE MATERIAL with said texture) but I don't know if it's possible to extract the texture name from a REQUESTed material.
If you already know which texture you want, you could hardcode it directly maybe.
runxel
It's possible, even tho you must need to do some contortions.
file_name = ""
rrr = request{2}("Material_info", old, "gs_mat_texture", file_name, w, h, mask, alpha)
define texture "new" file_name, w*2, h*2, mask, alpha
tex_id = ind(TEXTURE, "new")
str_name_of_mat = ""
rrr = request("Name_of_Material", old, str_name_of_mat)
define material "new_mat" based_on str_name_of_mat,
	parameters gs_mat_texture_ind = tex_id
mat_id = ind(MATERIAL, "new_mat")
material old
brick 1,1,0.1
addx 1.3
material mat_id
brick 1,1,0.1
Don't get hurt.
Victor Vernaglia
I copied and pasted your script (created the "old" parameter) and got the error message, am I doing something wrong?
"Error in definition of materials used at line 21 in the 3D script of file Untitled-1.gsm."
runxel
Could be a GDL bug? I encounter this too, in AC 28.
However it still works. So I'm not really sure why it's nagging here.
Victor Vernaglia
Yes, it's working, but this error message is very annoying. Thanks for the reply.
